Hi people, i´m working on a small project but i want to do a good work and i was wondering if you guys can gime some suggestions or advices to improve the render quality, like ilumination, textures or something you dislike. Thanks in advance
Microsoft Windows 7 64 Bits<br />Intel Core 2 Quad 2.33 GHz<br />Nvidia 9800 GT<br />8 Gb DDR 2<br /><br />rendersarquitectonicos.blogspot.com
hi... it's a great render...
i dont understand that about the flat illumination... i know what flat means, but i dont know what people really wanna saywhen they say that a render has a flat illumination...
check this...
hope that you don't mind... i just duplicated the base layer, and changed the copy's blending mode to overlay...
oh yep, and i added a few flares. i think it looks better ;D
flat means that theres not much contrast on lights, its when a scene lightning has no drama or correct contrast then is flat....also when you look at areas that has lamps or ies and just looks the same than all other parts of the room
Rodrigo: the outdoor image needs a lot more of brightness, and for me the render needs more brightness too. but keep up the good work bro!
Hahaha Omar i can't believe what you did with the image, it looks great!!!. Thanks a lot dude for the tips. I'm starting to believe that whitout photoshop i will never produce a great render. BTW how did you add the flare ???
Teo: Thanks for the explanation about flat ilumination, i really did not understand what you mean whit that and i appeciate that you took the time. About the outdoor image i will try to control better the brightness.
Thank you guys ;D
But guys what can i do to control better the ilumination? I actually turn off the wall behind the camera to add more light to the image and i used these phisical camera values:
shutter speed.................4.0
fnumber..........................5
film speed(ISO)...............4.0
I think those values are too low but they where the best combination that i could find.
BTW i'm using 1.48.89 version
yo creo que tu iluminación está bien... el photoshop siempre empuja los renders a un siguiente nivel, pero de hecho, cuando yo vi tu render me gustó como estaba. el truco es que antes de trabajar con los materiales, tienes que jugar con la phisical camera y hacer muchos, muchos renders... y cuando llegas a cierto punto y estas contento, pasas a los materiales y luego al photoshop... respecto a tus valores... yo nunca uso los mismos... asi que supongo que están bien.
te mande un mensaje por cierto...
you speak spanish, right? ;D
Hola Rodrigo dejame primero que nada saludarte y decirte que tus renders tienen mucho potencial, lo unico que me molesta un poco en tu iluminacion es que se ve muy azul, y ya que mencionastes que estan usando la ultima version del vray sucede que si has quitado la pared de atraz tu iluminacion y todos tus materiales tendran ese tono tan azul que se ve en el render, yo te sugiero lo siguiente que juegues con los valores de la phisical camera, el shutter speed juega un papel importante en la iluminacion, recuerda que valores mas bajos mayor iluminacion y tambien el film speed valores mas altos mayor iluminacion para la camara, en vez de quitar una pared entera mejor haz un boquete en el vielo razo en la parte de atraz o haz ventanas, Tambien otro consejo que te doy es que en algunos casos uses luces rectangulares es una manera mas facil de controlar la iluminacion, Y por ultimo si usas el vray sun, te sugiero que juegas con los valores de multiplier la nueva version de la ventaja de usar el vray sun y tambien usar la luz del GI skylight, lo que puedes hacer en vez de quitar la pared de atraz ponle un valor alto al gi skylight. Bueno espero no haberte confundido y esto te sirva mucho, es que la verdad hay tantas maneras de controlar la iluminacion pero creo que mencione las mas importantes.
Thanks for the comments and the tips guys and of course i speak spanish!, Who doesn´t?? hahaha
Muchas gracias Omar y David, me alegra mucho el interes que demuestran en ayudar a novatos como yo por aca, seguire sus consejos y tratare de actualizar la imagen a la brevedad posible para ver si encontre un mejor resultado.
Thanks everybody!
