splotches
  • splotches
    i just can't seem to get rid of all the splotches and light leaks from this scene.
    When i switched from direct comp. to global photon for the secondary bounce in the scene, then all these light leaks and splotches showed up. i went through the 'splotches' tutorial and did everything it said, but the splotches still remain. i believe that i have solved the one in the middle - the pendant light wasn't cleanly built - so after rebuilding it, it fixed that problem. but, all the errors still show up on the left hand side of the image.
    my gobal photon settings are:
    thanks in advance.
    I think the interpolation samples are way to low...photons too...
    ____________________
    www.formfest.de
      hi
      well start by hiding the objects from your scene and keep checking ..when the splotches dont appear then thats the problem for you... if you want post the scene we can try to take a look
      cheers
