HOSPITAL Emergency Room- WIP
  • HOSPITAL Emergency Room- WIP
    Can anyone look at this glass and tell me what my problem is...
    I have no GREEN in any part of the material...And I cant believe the green reflection is coming from the grass. I have even turned down the receive and generate GI - grass settings.
    Also, Look at the glass at the ground level...Its cut at wierd angle with that green tint.....
    Here is the glass settings:
    I read a recent post talking about if window glass is single sided (no thickness)to use a double sided material. So I used the settings below for both sides, but no difference.
    If someone could look at this file for me, I would really appreciate it..Im pulling my hair out with this glass thing! TIA!!!!!
    Attached is the Viz file....
    http://www.sizeler.com/vance/lourdes.zip
    Arkitec,
    I've seen your scene and realized that you should make your glasses with some thickness, otherwise it won't render refractions correctly.
    Try to put some thickness on the windows and you'll see it.
    Regards,
    Joao.
      If your glass is a plane - you can make it have thickness really quick by using Solidify script. Works like a charm.
        Thank you for the quick reply.....
        LOVE THE PLUGIN....EASIEST EVER...Worked out great.
        THANK YOU AGAIN.
        ARKITEC
