Thanx Fernando! The render was done with much help from your tutorials (caustics & HDRI settings)...that was basically the inspiration for doing this one. Any tips on improving on quality (I know I still have to stock & fit-out the bar hehe) My visopt where roughly:
- Image sampler: Adatpive DMC, min subdivs 1, max subdivs 8 (default)
- Indirect Illumination / Primary Enging: 1.0 Irradiance Map (default),
- Indirect Illumination / Secondary Engine: 0.85 Deterministic DMC (default),
- Irradiance Map / Basic parameters: min rate -4, Max rate -1,
- Caustics: Max photons 100, Max density 0.0, Multiplier 2.0, Search distance 20.0.
Maybe increasing subdivision in some areas? I have not too much knowledge about the settings when it comes doing the 'final' render (this is the first one I have done at a bigger size of 2048 x 1536 pix, render time @ 7hrs on iMac Intel Core Duo 2 GHz 2 GB RAM).
