w o w... great illumination!
i think that if you edit the flares you would achieve a better result, remove the spiky glow...
i use a lot one flare that is named "basic spot light".
about the exterior, it does look a little bit blurry... it's the background of the hdri, right?
@ samo : Yes you're right but i cannot edit it, coz its from the HDRI
@ omar : Thanks bro, I'll consider to change the IES, and yes it's HDRI
@ fpedrogo : Thanks for the input pal, noted the suggestion. Thank you very much
Hi nawaitsa
You can use the HDRI in the GI environment and reflection slot. Leave the BG slot empty. This way you will
have a rendered image with the lighting and reflections from your HDRI, but with no background.
Make sure in the VFB channel you have the alpha mask on. I would then save your image as a PNG.
Now in PS you can include your HDRI in the background and control the Brightness/colour/exposure....etc
@German : thanks you very much, it's still not perfect though
@Holmes : Woow never knew that before, thanks for the valuable lesson. I'll try it... again thank you
