Here is an apartment building that I am working on. The trees are blocking the building, but the landscaping plan is accurate, and the client picked the view. I am generally happy. I am going to render it again, fixing a couple things, and without the trees that are blocking the building. Any other comments and suggestions are welcomed.
Three Story Apartment Building
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Looking good Bobby,
few points on my side:
- i would scatter more foliage of the types you have there...just to thicken it
- maybe little less saturation on the foliage and lighter skyMartin
http://www.pixelbox.cz
yes, I agree with allBobby Parker
phone: 2188206812
- Windows 11 Pro
Great image, I wouldn't say the sky is too saturated, probably a little too busy with the clouds.
I often refer to archectural photographers website for a bit of a reality check, ie. with real world colours and lighting etc.
Our local architectural photographer legend (imo) is Scott Burrows: http://www.aperture.com.au/
Also I find if the building/shot is quite busy a clean sky works best and visa-versa.Last edited by bob-cat; 27-07-2011, 03:27 AM.
Yes. I am going to remove the foreground trees. The sky was something I grabbed, and dropped in, at the last second. It isn't a typical sky I use and I don't like it either. Does anybody have any good setup for multiscatter grass? I think multiscatter is good for natural environments, but not well kept lawns, at least I haven't accomplished it yet. I wish my Autograss worked!Bobby Parker
phone: 2188206812
- Windows 11 Pro
Looks pretty good. The scale of the ripples in the water looks a bit large. Out of curiosity what method are you using to get the soft/bloom look?Jeff Adams - Freelance Architectural Illustrator
http://www.jamodeler.com/freelance/
The water was a last minute deal and I didn't have much time to work on it. I use the NIX plug-in for Photoshop to get the soft focus effect.Bobby Parker
phone: 2188206812
- Windows 11 Pro
like everybody else, the saturation is too high, the sky IMO is out of scale as well and I would take/replace those red trees since the building is pretty much red...the trees on left side are off too, they should be smaller.
Fernandoshow me the money!!
phone: 2188206812
- Windows 11 Pro
The color of the brick looks too different in each rendering that it looks like you have a complex of 4 building in there...about the water, it needs bump and the color has to be darker (dark green), I will put some wildgrass around the pond too.
there is a tree in view 4 is not casting shadow and another one is too close to the windows.
FernandoLast edited by flino2004; 30-07-2011, 12:58 PM.show me the money!!
Good eye Fernando, thanks. I did notice all you mentioned, but I was already up for 2 night trying to get the job done. I have a question for you guys. Is there a mathematical equation that will change one RGB to another in Photoshop. It seems there would be, but for the life of me, I can't figure it out. If I have an RBG of 32, 200, 96, and I want it to be Red, how would I accurately cange it (other than replace color, which is the slider)?Last edited by glorybound; 30-07-2011, 01:53 PM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
