xtrm3d little corner ..
  • #16
    thank you ..
    yes,
    v-ray toon lines pass , plus another pass with shading ..
    then mix and blend in post
    • #17
      wanting to make sure that i still know how to handle vray .. after spending too much time with mental ray lately
      • #18
        nice render
        www.framecg.com
        • #19
          thank you
          here ,
          wanted to see if i could do something along teh line of the look of ""fake it"" from mike nash
          not too bad i guess for a first pass
ID:	846347Click image for larger version
          • #20
            doing some more look research
            • #21
              and even more ..
              maya 3 tone toon shader ( rendered in vray )
              vray toon
              vray dirt pass (ao )
              + post in photoshop
              • #22
                Looking great. Is any of the dirt overlay added in photoshop? Do you have anything to map the cross hatching lines to a correct angle?
                • #23
                  on the yellow car , the dirt is painted in the texture ,
                  as for the cross hatching i can control the direction across all the image but not per region basis , although it should be doable in fusion or after effect
                  • #24
                    nother lighting test
                    • #25
                      Your AA is too sharp on your forearm no ?
                      www.deex.info
                      • #26
                        yes .. way to shaarp ..
                        it's a post issue .. not a vray one
                        let call those one final for now
                        • #27
                          [ATTACH=CONFIG]12322[/ATTACH]
                          [ATTACH=CONFIG]12323[/ATTACH]
                          Yes, it is better now !
                          www.deex.info
                          • #28
                            done with teh car so far .. time to concentrate on the crew again
                            • #29
                              back to vray with this one ...
                              still have to redo the rig .. then starting on the painting of the masks for the material
                              • #30
                                two other one.. as i was doing some vray vs octane comparison
