Château BACCARAT // PhoenixFD Force on PF rendered with Krakatoa
  • Château BACCARAT // PhoenixFD Force on PF rendered with Krakatoa
    hello,
    this is my last job and i have used phoenix FD to apply very naturals and beautifull move on my particles flow .
    It's rendered with Krakatoa. This is my first attempt with Krakatoa.
    look here at full screen HD for better experience :
    https://vimeo.com/38839628
    let me know what is your feeling to help me to improve my art
    best regards !
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    good job, how many particles?
    ______________________________________________
    VRScans developer
      i haven't take a look at how many particles are computed with Krakatoa.
      In particles flow i begin with 2x 2 000 000 particles wich spawns themself 200x times per frames and a long life time.
      Then i use krakatoa 10x partitionning .
      So ....
      a lot too many so much particles or something like that
      The thing that i really love with phoenix FD in this job is that we can compute a very basic low precision grid with only thousands particles generated to apply a fine detailled force to the PF particles system .
      What i dislike is that the PhoenixFD forces PF system is so slow that it's make the work hard .
      it's seems to be a Particles flow issue, but can you do something to make your particles flow PhoenixFD operator faster in particlesflow?
      And i need your advice. is it better and faster to go to thinking particles or keeping Particles Flow and adding Box 2 and 3 is enough ?
      freelance 3D artist
      www.ghiom.com
        phoenix has its own particles that run much faster compared to the PF setup, but they still can't be directly transferred into a PF event. they can be used if you need just particles moved along the fluid, but as i see in your case this is not satisfied.
        perhaps we will add a pf birth operator, that converts the particles in a phoenix simulator into a pf particles
        VRScans developer
          it's could be great this PF birth operator.
          I have other jobs where i need to drive particles with Key frames and/or Path Spline and having fluid forces on them to make secondary motions.
          I have try to make a drived particles flow as emitter for phoenixFD, but it's not so much interesting if you just want to make a water flow dancing around something or following a path .
          freelance 3D artist
          www.ghiom.com
