Need Your Help
  • Need Your Help
    Hi everyone!
    Blotches...in colour this time...
    Have downloaded the material update from vray, new updated vray
    version (n), everything has a thickness to it, vray light has sub.div 8,
    no standard max raytracing
    hmm, I'm totally going crazy - help, please - anyone...
    You can view the render here:
    http://vr.reaperfields.com/images2/b.jpg
    You see that on the floor, on the furniture, behind the sofa and
    the orange on the cash desk...Whats going on?
    Cheers
    Anders
    Wat are your GI settings?
      Cheers for answering Vlado!
      My Settings:
      First Bounce Min Rate -3, Max Rate-2
      0.75
      HSph
      40
      Interp Sample
      40
      Second Bounce
      0.75
      Global photon map
      Bounces
      30
      Interp sample
      30
      Search dist
      100
      Max photons
      30
      Multiplier
      1
      Max density
      40
      Raytrace Threshold
      2
      Ratrace bounces
      10
      Best
      Anders
        Photons
        Hello again...
        Now I have turned off the Photons and it renders without
        blotches. Is that a common problem - that Vray light and
        photons clash? Are my Photon settings madly wrong?
        /A
          I had a similar problema little while ago, the fix was checking your materials and making sure you have no raytrace materials.
          Chris Jackson
          cj@arcad.co.nz
          www.arcad.co.nz
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
            number of bounces and retrace bounces must be the same,
            maybe also you check the "check sample visibility" in the advanced imap rollout. I think this causing one of the spots where surface meets.
              Cheers!!!
              Will try that now!!!
              Thanks
                Tried what you said, doesnt work.
                Cheers for aswering!!
                Thanks
                Anders
                  check your email.
                    Maybe it could be a caustic problem? try to turn off G/R caustic for objects in vray object properties
