Basic Ocean test
  • Basic Ocean test
    Ivaylo.
    I am sharing a better simulation result of my test, after you explained
    How to setup the Ocean vector displacement and avoid cliping.
    Foam and splashes are still working in progress,
    my bad, I can't properly tweak it , if I get a good result or turn Force on
    Motion Blur, render times increase unreasonably.
    Can you share the setting of the foam shader? Motion blur can produce a lot of noise which is difficult to clear. This shader can become pretty heavy.
    V-Ray/PhoenixFD for Maya developer
      what means "unreasonably", 2-3 times is prety normal. anyway, you can control it by the motion blur step and motion blur limit parameters. increase the motion blur step to make it faster, if the quality is good enough.
      ______________________________________________
      VRScans developer
        Thank you Ivaylo.
        Send me an e-mail adress and I'll send the whole scene if you want.
        mine is :
        lzmihich@gmail.com
        I am sure that I can reduce the render times with the foam shaders .
        I can tweak motion blur, But i am afraid I also have scale issues.
          You can send the scene to our mail - phoenix@chaosgroup.com.
            scene and HDR files already Sent.
              well, i will have no time this week to run your scene, hopefully next week.
              VRScans developer
                lzmihich, can you test with the next nightly? We will make a small change there to check if it helps. If not, Katev will investigate the problem further when he can.
                  There's no rush at all.
                  I understand that Phoenix 2.0 service pack was just released, and Ivaylos are being very helpful.
                  Publishing my efforts is also meant to help.
                  I 'd love if in the future,We would have an Ocean specific tutorial.
                  Thank you.
                    How can I access the latest nightly to download ? forgive if it is an obvious answer.
                    From the download sections on my account , the same version of Phoenix 2.1.
                    that's it ?where Do We dowload the latest nightly from ?
                      ask the support, they have to update your access privileges and will explain you how to download the nightlies.
                      VRScans developer
                        Sent an e-mail to support.
                          Did you look at my scene ? Are the tutorials on Ocean scheduled for soon ?
                            your scene is ok, it seems to me that you just need to tweak it.
                            the tutorials are in progress, it just goes slowly
                            VRScans developer
                            • #15
                              Ok Thank you Ivaylo.
                              I am studying the manual and the samples, for while, to find out a litlle bit more about How to tweak it.
