Architectural Details
  • #16
    Just a tad bit of motion blur on the butterfly would be nice. Other than, that it looks REAL!
    • #17
      My glass does look to perfect, and I thought about faking it in PS.
      Originally posted by Morbid Angel View Post
      Couple of notes, if you are aiming for total realism. This is strictly IMO The forms in the image are really too perfect, in real world nothing is this straight. The wood on the doors etc, everything is really clean. See this image I've got:
      http://www.flickr.com/photos/light2m...13912/sizes/l/
      Look at the glass panels, though highly reflective, they are not perfect, the glass tends to warp a lot, when in side the frame, it creates irregular reflection/refraction. The line that meets the pebble on the floor with the wall is also very straight for me. At this distance, I would use scatter to actually place real geometric pebble which would give you much more natural look, then displacement.
      Cheers!
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #18
        I think it looks really good, but what catches my eye is the edge between the gravel and the wall.
        • #19
          Thanks. I purchased the gravel library from Arrowway, and they have some kind of edge alpha, but I haven't had time to play with it.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            Originally posted by cubiclegangster View Post
            The reflective coat is a black material with refclection set to 255,255,255 and the glossiness on .975. the noise bump is very subtle & quite large.
            The falloff used to mix between them is simply a fresnel - might want to note that i've got it over black and not set to 100. The wood has very soft glossy reflections to pick up it's own subtle highlights and the details of the bump underneath the varnish coating.
            [ATTACH=CONFIG]16027[/ATTACH]
            Are you using Fresnel reflections in your base material?
            • #21
              I think perhaps you try to do too much with textures to get something memorable.
              • #22
                yeah, ior 3 or something & the glossy value works out to something like .6-.8
                • #23
                  Here is an update. I am not sure if it is better, or just different. Basically, I brought the wood back to its original state, warped the glass a little, put a motion blur on the butterfly, and fixed the rocks from breaking at the wall.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    Yep wood looks much better!
