Day and night lighting renders
  • Day and night lighting renders
    Continuing my discovering of VRay I made several interior renders with day and night lighting using self illuminated meshes.
    Re: Day and night lighting renders
    When using Emit, you need to highly increase GI quality to avoid dirt like this.
    [attachment=0:373jq7so]build2_vray_9.jpg[/attachment:373jq7so]
    [attachment=1:373jq7so]build2_vray_8.jpg[/attachment:373jq7so]
    But the better way is to use arealights with mesh emitters.
    andrei.izrantcev@chaos.com
    Support Request
      That is quality ! Congrats...
        I use Lamps in instead of mesh light... I some case, of course!
        Man, your rendes are beatiful! I really like the 3 and the 5 one. But in the 4 one... What 's that white dot on the both sides of the wall? And... Can you share with us the frosted Glass material in the fifth render?
        Blender + Vray!
        My blog
          Very nice.
          I agree with Andrey on the blotches - It's not efficient to try and light a vray scene with mesh lights. Better to use normal lamps.
          Check my blog
            Thanks guys,
            Indeed I noticed that it's quite difficult to get clean results using mesh lights, so I should replace all the mesh lights with normal lamps (This scene was setup for Indigo), I'll probably try later on but I'll consider to use only lamps for the new scene I'm working on.
              Get settings for glass and then set following parms :
              Ray mirror on
              RayMir slider : 0.15
              Ray Transp Gloss : 0.85
              I used Blinn material with 0.8, 58, 4 values
                Thanks man! I won't know this values of the Shader make diference!
                Blender + Vray!
                My blog
                  I changed some lights from mesh to lamps (area lights), and indeed even if there are still some blotches, the result is much better with a lower rendering time.
                  Edit : I added some more images.
                    Your last scene are incredible! I really like this one.
                    Blender + Vray!
                    My blog
                      Very nice
                      ...do you want to make your dreams come true? Wake up!
                      http://www.djscore.org
