new interior
Very nice work, as nice as the exterior.
I also have a suggestion:
About the people, they are image-based, like the RPCs I use, here's what I usually do in photoshop to make them look better:
1: either sellect the person, or render a mask,
2: then, try to play alittle bit with the saturation and lightness and contrast, so it gets better blended with background.
3: now you must, (if very adjacent to strong light from one side), make some light adding with the gradient tool, for example, for the nearest man in gray suit, add some whiting to the right half of his image, as I remember the setting for the gradient tool is called "foreground to trnsperant".
4: You may need to redo step 2 more than once.
5: Finally, select the person, and add a little bit more selection around it, then use blur, until you find nice, this is how you can get rid of the sharp edge between the person and background.
Hope you find this useful.
By the way, about the interior decorating, you made it, or it is a known architect? looks nice!
fantastic image, my only problem with it is the glass, it looks a little too transparent. Play with the refraction a little.
What are your render times?
keep up the great work
nice work...really good lighting!!!!
mi only comment is the glass on the right seems like it's hardly reflecting. maybe fresnel or a falloff map in the reflection channel could make it pop a little more.
the RPCs are a little distracting, especially w/ motion blur.....but it all looks great!!
can you share your lighting setup??
paul.
