shelter - WIP
  • shelter - WIP
    vray 2.0 | vrmesh proxy testing
    grass & trees
    wip
    z e r n a n s u a r e z - "zdesign"
    final test view
      looking good! I like how you've adjusted the colors from the first one. Very lively scene. Great job!
        thanks andybot_cg
ID:	851784Click image for larger version
ID:	851785Click image for larger version
ID:	851786Click image for larger version
            top view
              parallel projection - https://www.facebook.com/media/set/?...6868492&type=1
ID:	851835Click image for larger version
ID:	851836Click image for larger version
ID:	851837Click image for larger version
ID:	851838Click image for larger version
                Very nice renderings. How did you spread out the grass proxy? Make_fur plugin?
                  i use make crowd
                    great work, can you show how you did the grasses?
                    Thanks. Gonzalo.
                    The best that I can do is keep learning, and the Renderings are just a small step to get real.
                    THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                    http://WWW.URBANGROUPUSA.COM
