advice
  • advice
    Hi All,
    Here are few shots of a space that is getting designed and rendered. I am looking for some advice on how to get my images more photo real and high end.
    I am using a vray sunlight through the windows and ies lights for the space.
    Any thoughts would be appreciated.
    Cheers
    Alex
    Here are my render settings for the scene.
Name:	rendering settings.jpg
ID:	856098Click image for larger version
Name:	rendering settings01.jpg
ID:	856099Click image for larger version
Name:	rendering settings02.jpg
    Cheers
    Alex
      I don't think it's a rendering thing, it might be more of a composition thing. Maybe, lower your camera. Also, some contrast in post might go a long way. Are you using real world settings for lights and camera? I find when I use real world settings my image look more real.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        Thanks Bobby. I one reason I had the camera shots a little higher is because its such a small space so I was trying to get in as much as possible. But I can certainly try that. Def adding some contrast would help.
        Thanks allot
        AM
        Cheers
        Alex
          For small spaces they recommend shooting into a corner.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Showing too much ceiling make you feel claustrophobic. Also, a little depth of field might help.
              Maybe some more accessories, Coffee maker, glasses, newspaper, food...
              Cheers,
              -dave
              â–  ASUS ROG STRIX X399-E - 1950X â–  ASUS ROG STRIX X399-E - 2990WX â–  ASUS PRIME X399 - 2990WX â–  GIGABYTE AORUS X399 - 2990WX â–  ASUS Maximus Extreme XI with i9-9900k â–
                I notice it's missing the ambient occlusion (AO) personally i don't use the AO included in the Vray global illumination panel (expert) because u cannot control it
                i rather render with one or two extra layer (render element)
                in vray render element select - Vray extratex and apply in the "TEXTURE" a vray dirt map
                (the next step would be to instance the vray dirt map in ur material editor and twick the size of the dirt to create one for detail object (smaller range) and one for ambient (larger range) and then blend them in photoshop)
                this will create an extra layer of Ambien occlusion that u can save by itself and apply in photoshop and mask the area where u don't like the ambient occlusion to show
                Ambient occlusion give an extra 3 dimensional feeling to your image
                it work more or less like the suggestion of the "extra contrast" the other guy gave you but in a more architectural correct way
                first is the layer of AO
                second is the image without AO
                third is the image with AO merged in photoshop
                This is the biggest suggestion with the major impact i can give you on your renders
                  same comment from your other post.
                  show me the money!!
                    I am against ao, ao is not correct in interiors especially.
                    In any case, to me it seems that your textures are too dark and contrasted, you are lacking reflections which is a key component in making things photoreal. For example the floor looks like mostly diffuse and zero reflection. Are you working in linear? you should consider that.
                    And also more detail, more of what others suggested already.
                    Dmitry Vinnik
                    Silhouette Images Inc.
                    ShowReel:
                      that's why u have to use a different layer for the AO and then use a mask to remove it where u feel is wrong and lower the transparency to 50% or less depending on ur taste but saying AO is wrong in interior is not correct
ID:	856107Click image for larger version
ID:	856108Click image for larger version
                      take the picture of any corner in ur home and u will understand what AO is it's a natural effect of the light it cant be "wrong"
                      but i agree it is wrong as it is rendered in Vray just clicking the option in the global illumination panel and expecting a realistic result but from there to go to the extend to say AO is wrong there are medium grounds
                      everybody that play video games know that graphic look much better with AO "on" more realistic and more 3d
                        Thanks Jeff
                        Cheers
                        Alex
                          [ATTACH=CONFIG]24326[/ATTACH]
                          I found when I use the AO render element it darkens the space to much, perhaps my AO settings are in correct.
                          Cheers
                          Alex
                            Thanks Dmitry. I will look at the textures and bump up the reflections. I am working in Reinhard not Linear. What is the difference?
                            Cheers
                            Alex
                              Reinhard is between linear and exponential, I think. Exponential will brighten the interior, but might blow out things. Reinhard dulls the hotspots, but does make for a flat image, which can be corrected in PS with a curve.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
