Animation Test using photons
  • Animation Test using photons
    I have some free time this morning and take it to make several test with photons and interiors..
    There are 2 lights, one as sunlight (free spot) and another one in the window, as a skylight portal. I think that the light distribution is right, and there are no visible (almost) artifacts and dark corners, that is exactly what i want to get.
    the photon distribution:
    the same scene using imaps+direct as secundary:
    the animation:
    http://www.indigooo.com/foro/phtm.avi (2.57mb 17sg, xvid)
    render time per frame was about 1 minute at PAL res (only render, i compute first the imaps -3 0, and photon map to use them later) in a p4 3.06 HT
    Not bad. The antenna's shadow is missing some frames (1 at least).
    You should more refine your imap solution without any problem with such a scene.
      ouch, i thought it was an AA problem
        wow love that military truck. Would look perfect in a project Im working on
          lol
          www.3d02.com
