My first try on Vary(setting attached)
  • My first try on Vary(setting attached)
    This is my first image of Vary~I think the rendering time is quite long. There must be a way to short it~any common and suggestion will be appreciated.
    My PC is P42.3c, Memory 512mb, Elsa Qurado 380xgl
    Thanx again~
    My guess is that you have a weird antialiasing setting that's very time consuming. Try to switch to the adaptative subdivision mode, at least for the previews...
      the fixed rate AA method is rarely faster then the adaptive.
