Attraction Bubbles
  • Attraction Bubbles
    Hi there,
    Just play'n a bit around with attraction force,
    https://vimeo.com/136595032
    i've turned the std. gravity off for the simulation for the foam to stop. But i noticed that the simulation reacts different when i set the gravity to 0, or disable the gravity. When i leave the G. enabled and set to 0 the foam continou'd to move.
    Even when i change the gravity to .5 f.e. and disable it again, the foam reacts different..
    Is is intended? does it make sense what i've try'd to explain..?
    Do i have to set the falling speed to 0 for the foam to stop?
    Best regards
    Jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    yes, your observation is correct, the underwater movement is controlled by the rise speed, that gives in account only the direction of the gravity, but not it's magnitude. thanks for the point.
    and the animation is really good and original !
    ______________________________________________
    VRScans developer
      Ok i See. Thanks man.
      Jonas
      www.jonas-balzer.de
      www.shack.de
