Taramac Development
  • Taramac Development
    I have a ways to go, but here are some early views. I don't plan on these aerials being the finals, but I just wanted to show the scope of the project. There's a whole commercial part, but I am waiting on the owner for some colors.
ID:	882721 Click image for larger version
ID:	882722 Click image for larger version
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I am thinking cars will break up the pavement.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      its looking good
      couple of things i would have done differently
      1-use a direct light like a sun for more contrast
      2- i would have made the tarmac darker with a glossiness map .
      best regards
      www.kobo9.ch
        Yes, the pavement did come out light; I'll fix that. I like more contrast in images, however from my experience clients don't. I'll play a lot with light and shadow as I progress.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          awesome stuff. you post more images than everyone else combined! lol. very inspirational. keep it up.
          -don't like the yellow trees
          -nothing is blooming? no flowers or flowering shrubs?
          -put some hvac stuff on the roof? it would be more real-world that way
          -thats alot of pavers!
          -are you using forestpro?
          -the flat roofs don't look right. maybe a much lighter color to reflect solar gain? Like white membrane?
          • Dual 3.47 ghz Hex Core Xeon CPUs; 96GB Ram; SSD Drive; 3dsMax 2020; V-Ray; Sketchup 2020
          • Love these Plugin/Scripts: ForestPro, RailclonePro, Soulburner, Populate Terrain
            I am not sure I'l be showing this from this view, so I am not going to spend any time in the roof; we'll see. I am not using ForestPro. I have had big issues when using it for more than a couple ForestPro helpers. These are proxies, so I can swap things out easily. When I start to pull street level views, I'll tweak the vegetation.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I don't like the yellow trees, either. They are supposed to be "small flowering trees", so I'll look for something better. I saw that XFrog had a library. I do have XFrog, but I haven't used it in years. I tried to install it, but nothing worked (clicked setup and nothing happens), so I downloaded the trial and that didn't install. either. I have been buying XFrog trees, which comes with the MAX version.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                In addition to the roof ventilation units mentionned earlier, I'd also add flat roof draining bassins to break up the surfaces.
                  I guess in actuality it would be a parapet wall, however I didn't have working drawings, so we haven't talked about the roof.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    First ground level image test.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Im always in awe of your work! nice job
                      Cheers,
                      -dave
                      ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                        Thank you, very much! A lot of work to do; I am kinda working with a large brush down to a fine brush. I worked the whole scene, as a whole, and now I am working on views; fine tuning things I didn't see in the big picture view.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          I took the plunge and bought some Vizpark trees. Havent used them yet but they seem very nice.
                          http://www.vizpark.com/shop/real-trees/
                            I'll check them out, thanks.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Dialing in a little closer with each view. Now, when I do finals, they'll be tight.
Name:	large apartment back.jpg
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
