Detached Houses in Marseille
  • Detached Houses in Marseille
    Hello everyone,
    Here is my last work: three detached houses in Marseille, not far from the sea.
    Software used: 3dsmax, VRay 3.2, AE, PS
    Hope you like it.
    C&c are welcome
    BOKEH Studio
    Nice work. I like the wide angle. Maybe, a little too much AO, but that might just be your style.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      I didn't add any AO but I turned on the Irr map Detail Enhancement. I also added a levels adjustment layer in post: maybe I pushed the dark point a bit too far, resulting in an over contrasted image for your taste. That's rather a subjective stage but ... I think it is also the interesting point when dealing with CG.
      Thank you for your feedback glorybound
      BOKEH Studio
        Just looked at them again, on my 4K and they are extremely well done.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Thank you !
          BOKEH Studio
            Lovely work - quite dreamy in places
              Thank you John !
              By the way, I have to thank you for your great video "Sampling for Arch Vis renders": it just changed the way I use VRay. Now I have smaller render times and no more AA problems
              BOKEH Studio
                Ah, great to hear Thomas. the ideas in that will always work for vray but Vlado and his team are trying to make things a lot more automatic so hopefully in future service packs no one will have to listen to another hour of my boring voice
                  Once you began to understand how VRay works, you can't go back and switch to a more automated way (imo). I hope VRay advanced settings will still remain accessible in the future.
                  BOKEH Studio
                    Yep - the nice thing is there's kind of rules about what objects need aa and what objects need materials - that's what the guys are trying to automate.
                      It sounds good ! I can't stand testing it
                      BOKEH Studio
                        I love the style and light balance between the sharp sun and interior light. If you could spare any tips on achieving that I'd like to hear them
                        PGDesigns.co.uk
                          Thank you PGD,
                          I'm glad you like my style
                          Here are few words about my workflow:
                          _ the scene is lit by a VRaySun + VRaySky as environment map
                          _ VRayLights set to Portal (simple) on every windows
                          _ the background is a curved plane with a VRayLightMtl on it
                          _ VRayColormapping set to linear (gamma 2.2)
                          _ rendered frame is 32bits float .exr to keep the full range lighting informations
                          _ it doesn't matter if some areas in the render are blown out: I then use Fusion to tonemap the render and then I flatten it to 16bits. You can also tonemap your render with the built-in VRay Frame buffer tone mapping tool but I prefer doing it inside Fusion as it comes with more advanced settings
                          _ in Photoshop: I play a bit with level curves and color balance, on the whole image or on certain aeras/objects only, to achieve the desired look (VRayWirecolor pass and/or VRayObjectID passes are used here)
                          _ I can enhance reflections and specular levels if needed with the VRayReflection and VRaySpecular passes set to Screen mode
                          _ Also I like to play with flares (real world photos set to screen mode work fine most of the time)
                          That's pretty much it !
                          Hope it can be useful
                          BOKEH Studio
                            Fantastic, thanks for that. I think the key there is the 32bit and Fusion, neither of which I've tried.
                            It would be nice if V-Ray could output as a DNG file which could then be edited with Adobe's Camera RAW editer (comes with PS) That's the way I edit my architectural photos so the workflow would be familier. Maybe one for the V-Ray suggestions box..
                            PGDesigns.co.uk
                            • #15
                              Why don't you try 32bits TIFF output ? this way, you could enjoy PS Camera RAW, no ?
                              Nicolas Caplat
                              www.intangibles.fr
