Oak Park
  • Oak Park
    This one is going to be watercolorish, however, here they are so far out of V-Ray.
Name:	houses 1 and 2.jpg
Name:	houses 3 and 4.jpg
Name:	houses 6 and 5.jpg
Name:	houses 7 and 8.jpg
Name:	houses 9 and 10.jpg
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    One of ten.. good grief, this is going to take me forever.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Great render times. 4K with trees, grass, gravel, displacement, and reflections on everything in 4 hrs.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        House 2 - I am not sure the wet asphalt works in this one. This one only too 3 hours at 4K.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I don't think the wet asphalt works in any of those houses.
          there is something with the mood of the scene that is not working as well
          show me the money!!
            Originally posted by flino2004 View Post
            I don't think the wet asphalt works in any of those houses. there is something with the mood of the scene that is not working as well
            I would agree on the wet road. So far, house 2 is the only one you see the road on (on these set of proofs), so I'll probably change the road. Currently, I am rendering out 3, which the road doesn't show. The end deliverable on these is a watercolor filter, so I can't have dark shadows; I'm using an HDRI with little contrast .
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I am going to rethink this... Maybe, I'll add a V-Ray Sun and lighten up the shadows, in post, for the watercolor. This way, the client gets what she wants and I can use it for my portfolio, too. Updates to come.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                The asphalt doesn't look realistic maybe is why... Too many spots of water and very well defined.
                I really like what you have done before for your exteriors but these ones are weird looking.... Very CG in my opinion.
                show me the money!!
                  The asphalt doesn't look realistic maybe is why... Too many spots of water and very well defined. I really like what you have done before for your exteriors but these ones are weird looking.... Very CG in my opinion.
                  I'm reworking them, so I'll post updates later today.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Roof textures are very Flat Bobby...maybe some displacement would help??
                      they do have displacement 😒
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Here are the final deliveries. It would take a lot more work to make them photo-real, however, they wanted the watercolor feel. I might return to these, if I have time, just for my own pleasure.
Name:	House 1_Watercolor.jpg
ID:	859668 Click image for larger version
Name:	house 2_Watercolor.jpg
ID:	859669 Click image for larger version
Name:	house 3_Watercolor.jpg
ID:	859670 Click image for larger version
Name:	house 4_Watercolor.jpg
ID:	859671 Click image for larger version
Name:	house 5_Watercolor.jpg
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          And, the last 5 images.
Name:	house 6_Watercolor.jpg
ID:	859673 Click image for larger version
Name:	house 7_Watercolor.jpg
ID:	859674 Click image for larger version
Name:	house 8_Watercolor.jpg
ID:	859675 Click image for larger version
Name:	house 9_Watercolor.jpg
ID:	859676 Click image for larger version
Name:	house 10_Watercolor.jpg
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Although these are not Photo-real, I used V-Ray, and I am very pleased with things. I had two previous projects, both done in V-Ray, but both were started in an earlier version and upgraded to the latest, mid-stream. This project, I had anticipated long render times, however, the render times were outstanding. The two previous projects did not render nearly as fast as I was hearing on line; this project rendered in record times. The scene consists of 10 house, all with displacements, several Forest Pro elements, and DOF on every camera view (probably a waste of render time for these). Each still 1920 x 1080, rendered in about 35-45 minutes and 4K was 2-3 hours. For the finals, since they were going to be watercolor'ish, I only rendered them at 1920 x 1080 and doubled the size in Perfect Resize 9. I used a watercolor filter and a Pencil filter (the above images are prior to adding a pencil filter over the watercolor) inside FotoSketcher. The V-Ray setting were pretty much out-of-the -box. I changed it to adaptive and turned on GI.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Love them! You're a machine.
