Tp - vray rt gpu
  • Tp - vray rt gpu
    It’s been a long time I’m working with Vray RT GPU and after putting this quick scene together to play around, I decided to make a little edit.
    Hope you’ll like it
    Stan
    http://www.sbrusse.com/index.php/201...p-vray-rt-gpu/
    3LP Team
    Originally posted by 3LP View Post
    Hi, It’s been a long time I’m working with Vray RT GPU and after putting this quick scene together to play around, I decided to make a little edit. Hope you’ll like it Stan http://www.sbrusse.com/index.php/201...p-vray-rt-gpu/
    awesome! What card/s do you have?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      5x Titan X
      Stan
      3LP Team
        5x Titan X Stan
        Crazy! I'm sure once those cards drop in price we'll by using RT.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          60GB for about $5,000. What kind of machine allows 5 Video cards? Why are you using CPU, isn't the advantage of video, the RAM? Are you finding any limits that holds you back using RT?
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Well you could already have some 980 Ti for half the price of the Titan X.
            My scene was only using 4Gb of ram anyways so easy to get this in the 980 Ti and I didn't do a pinch of optimisation
            But hey, more for less is always better!
            I'm using a Asus X99-E WS who was supposed to run 7 cards.
            We have the 7 cards but never managed to get the computer to boot with more than 5. Bios issue I think. We haven't tried everything yet so I'm not loosing hope.
            But it would be easier to set up with dual xeons that will support 7 cards without any issue.
            It also pretty easy to get risers/splitters with host cards that will let you get 12+ cards onto the same machine.
            Stan
            3LP Team
              Very nice 3LP, we are using RT gpu also, but ran into some huge issues when RT wasn't rendering bump & reflection maps correctly. What do you do in those instances?
                interesting vid...
                where does this flickering at 20 sec around the bottom of the TV come from..?
                  Amazing, what were the render times like ?
                  Love the handheld camera work... almost creepy.
                  Patrick Macdonald
                  Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
                    Stan
                    Really nice work, good job!
                    Can you elaborate a bit more on the process of building you rig? How exactly does it look?
                      I love that you just created a full 3D environment for the backyard. Nice attention to detail and integration.
                      Gavin Greenwalt
                      im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
                      Straightface Studios
                        Originally posted by re:FORM View Post
                        Amazing, what were the render times like ? Love the handheld camera work... almost creepy.
                        if it's RT, it is real time, I would assume.
                        Bobby Parker www.bobby-parker.com
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Thanks for the kind words guys,
                          Unfortunately it's not real time yet.
                          Some frames where 10min, some where 20 depending on the cam.
                          I'd say it's a average of 15min per frame on 5x Titan X.
                          Stan
                          3LP Team
                            This looks definitely awesome. I am just curious , if you will compare price vs quality vs time spent on rendering , how will behave top CPU configuration in the price range of 5xTitans and what will be time outcome of it. Also one more thing , since we have limit for GPU memory - VRay takes all the 5 titans memory pool and uses it as one storage or it saves exact and same amount of information on each of the cards ?
                            Available for remote work.
                            My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
                            • #15
                              Very nice work Stan ! Fantastic lighting and quality. Loving the handheld camera feel. Well done !
                              Regards
                              Steve
                              My Portfolio
