Gray Stone on Hudson
  • #16
    I put a slight farming filter and I think it turned my sky a little Aqua.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      nice image, with what you used to create the fountain?
      Jackie Teh
      3ds Max 2023, V-Ray 7 Update 1 [7.10.00 build 00000]
      AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
      Website: https://www.sporadicstudio.com
      Email: info@sporadicstudio.com
      YouTube: https://www.youtube.com/c/SporadicStudio
      • #18
        Yes, but doesn't it create a mask for every layer? I work on layers, so it is a dream. Also, all the elemetns, with the layers, in one PSD. It's a lazy man's greatest tool.
        No you just select the objects you want a mask for and hit render. It's super fast and it's one of my most used scripts.
        • #19
          Everytime time I go into Forest Pack's grass material I just scratch my head, it's extremely complicated.
          I don't see the complexity. I never use the presets though, they're not that good, materials are always way off. I just create my own.
          About PSD manager, an EXR with all the render elements does exactly the same? I use it with Dave Wortley's Powermasker for all my different materials: https://davewortley.wordpress.com/20.../power-masker/
          A.
          www.digitaltwins.be
          • #20
            I purchased a fountain pack awhile back. It was pre-built.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              Have you ever opened a FP grass material? It is insane. I might be able to just drop one good material, I'll have to see.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                your machine is insane....glad it's working well for you!
                Sean MacNintch
                • #23
                  Thanks, I am very pleased!
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    Yes I did and I did change a few of those with color correct and better reflection settings, but is indeed quite time consuming. The thing is if you start doing it in photoshop (imho), you won't always have that good of result, because sometimes there's color bleeding because of the weird colors or the weird colors are visible in reflections,etc...
                    The first materials with textures and stuff are the materials that are inside the multi/subobject material of the proxies they use. The other (multi colors) you can just ignore those. Each color represents a different proxy in the FP object.
                    A.
                    www.digitaltwins.be
                    • #25
                      Thanks for the tip.
                      [ATTACH=CONFIG]29443[/ATTACH]
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        Instead modifying the material assigned to FP (this is generated on the fly), check each of the materials assigned to Geometry->Material and adjust those.
                        And most of times only it's necessary to modify one of them, because they are instanced when used on different geometries.
                        I hope that helps.
                        Carlos Quintero
                        iToo Software
                        www.itoosoft.com
                        • #27
                          The back of the house. It's been a bear, but I think it is coming alone. The bushes are millions, upon millions, of leaves scattered on boxes.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                          • #28
                            Also, render time was around an hour at 4K.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              Looks good. I would say the tiling (or whatever the ground material is) feels a bit too reflective. Also the pool could be a bit more realistic looking (just hunt on google for aerials with pools and photoshop it in).
                              But I think the thing that would really bring it up another level is to do something about the surroundings. If you can find a nice aerial photo with lots of grass and photoshop it in with the RawTotalLighting trick, it will ground it in reality way more (pun intended).
                              • #30
                                Yes, the pool, tile and surroundings need work. I purchased some high resolution grass last night, but nothing really worked, so I have to keep looking, Do you have any good resources?
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
