holograms
  • holograms
    two tests how the scanner behaves with holograms
    ______________________________________________
    VRScans developer
    VRScans developer
      hahah that is way cool! never imagined a hologram was "capturable" like that. would it work with a cd too? and f.e. chromatic glass? always hard to get those effects..
        yes of course, it will work with cd and any other magic-like materials
        VRScans developer
          brilliant. id still like to see a tray of desert sand top work!
            Heh, I didn't expect it to work so well
              That's pretty stinking cool!
              Neal Biggs
              3D Generalist | Freelance | Founder | Big5 Studio
              http://big5studio.com/
              3ds Max 2022 - V-Ray5 Update 2.2
                wrt the holograms, do you just get the colour shifting, or do you also get the parallax motion/3d effect when the viewpoint moves?
                  You mean how we do this internally? We have a scanning device that ,makes about 5000 photos of 2x2 cm square of the physical sample under different view and lighting angles , but in reasonable time (about a minute or two), then we combine them in a vrscan material, that is from 10MB to 200MB wide, depending on the features. If the physical sample is bigger than 2x2 cm, we put it afterward in a second device, that "enlarges" the small scanned sample to the full sized sample, without significant increase of the file size (proportional to the surface is not acceptable), for example if the 2x2 material is 200MB enlarged to 20x20cm it becomes 220MB, only 10% growth for 100 times bigger surface. These holograms are not using this stage, because they are small in size, but the most samples require it. The second phase makes possible to render without tilling, this is very important for materials like leather, wood, fabric etc...This is the kitchen process briefly, as user you have just to load the vrscan material and to assign it, this is all. Of course there are some tweaks, but they are mostly intended to accelerate the GI rendering.
                  VRScans developer
                    In short - yes, you will get the parallax
                      perhaps i didn't understand the question correctly, the spheres are used to demonstrate the materials exactly to give different view angles, you can see clearly that the nokia hologram shows paralax in the different part of the sphere, so i decided that the question is not about the presence of the paralax, but about how we achieve it.
                      VRScans developer
                        the videos dont seem to play for me in chrome, windows. but maybe its just my slow connection?
                        I see that you scanned different holograms of numbers, are you planning to add a simple hologram without any pattern so it is universally usable?
                        Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
                        www.AddYourLight.com
                        Always looking to learn, become better and serve better.
                          Hi Manuel,
                          We could not find any issues with the videos. They are uploaded to Youtube so you generally should not experience any troubles
                          As to the plane hologram, this is a fantastic idea and we will try to find such a material and update the library with it.
                          Cheers,
                          Dinko VP VRscans
                          Dinko Dimitrov
                          VP VRscans
                          Chaos Software
                            I can confirm,I can't see videos (chrome)
                            they seem to be upload to Vimeo, no ?
                            (Sorry for my bad english)
                            • #15
                              yes, i have the same problem, i think it's vimeo fault, here is the link https://vimeo.com/173726972
                              VRScans developer
