Applewood
  • Applewood
    The more I use Railcone, the easier it is getting, but it is a lot of work. The roof and siding is Railclone goodness.
ID:	885185 Click image for larger version
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Coming along nicely. I have more things to do, so I did very little in PS. I'll beef up the grass in PS, when I am done with the model.
Name:	front Color.jpg
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Coming along nicely. The copper is a little too red and reflective/clean to my liking. Glad you find RC useful. For cladding like this, shouldn't be that much of a hassle. I can see your roof through the windows of the dormers though . And your vegetation is a little too blueish.
      A.
      www.digitaltwins.be
        Did you use rail clone for the roof as well? The pattern on the garage roof is to repetitive. Can you vary the width of the shingles?
          Something is wonky on the garage roof and I am working on this. Yes, it is railclone
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Some updates
Name:	front color.jpg
ID:	863199 Click image for larger version
Name:	back color.jpg
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
ID:	863208 Click image for larger version
              Some minor changes. The windows, being black, are mighty dark. I did double up the reflections, but it still looks like black holes.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Looks like you have two sorts of lawn too.
                  Well, it might be hard to tell, but the camera is on a different plane than the house. I put that little path, which leads to a few steps, to kind of clue people about the difference in elevation. Also, like you said, there is different grass on the higher plane, which isn't nicely landscaped as the lower plane.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Try using the Reflection or Raw Reflection elements in "Normal" blending mode in PS. Then adjust the opacity (instead of the usual add mode)
                    Kind Regards,
                    Morne
                      I'll give that a try
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I usually use the reflection pass and mask it to the glass. I doubled the reflection up 3X
ID:	863233 Click image for larger version
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          [ATTACH=CONFIG]32334[/ATTACH] [ATTACH=CONFIG]32335[/ATTACH]
                          Well you're reflecting dark shadows, what did you expect would happen won't make much difference unless your lighting is different.
                          A.
                          www.digitaltwins.be
                            I have an HDRI wrapped around the house, so it isn't any different than my regular workflow. I think the black windows are making things look different than they usually do.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Maybe throw some window coverings inside might help a bit?
                              Cheers,
                              -dave
                              ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
