well you should look if you also can use the new internal. it gives you a grate boost in speed especially iin interiors, when you use lightmap for secoundary bounces.
photonmapping is much more complicated to setup , and also doesnt understand standartlights, environementlights and hdris, as lightmapping does.
your settings ar allright as i can see they do what they have to do.
what also could be interisting is, if you use glossys. and the settings of them.
