I made an animation showing the changing properties of brushed steel when the viewing angle changes. You can download it here.
(DivX 5.02 codec / approx. 1.5MB)
You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
It took me quite some time to achieve the desired result as in the animation. If you look at fine brushed steel, you can see that the reflection is blurred mainly in one direction, but also it seems to have an almost clear reflection on top of that. The blurry part is done with anisotropic blurry reflection. That was put into a blend material and blended with a normal reflective material.
To create the transition effect, the blurry material has a fallof map in the reflection glossy slot.
