w.i.p. exterior
  • w.i.p. exterior
    hi all
    its my last work
    c/c welcome.
    http://img98.exs.cx/img98/2725/geo-house-copy.jpg
    After a long wait for the image to load I finally manage to see it.
    Here goes my opinion about this work. I can't feel any bump in the stone textures or if there is it's not perceptible (try using displacement). The composition puts your house in a tree surround ambient, but you can't see any reflection of those same trees in the glass reflection. The rpc's for the flowers don't look good.
    Try fixing these problems and I think that the image will look a lot better.
      Fantastic rendering!
      Some minor things, just thought that there should be some trees reflected on the window glass, as Focusing pointed it out. Also what do you think cropping the image a little bit? the bottom seems a bit too much.
      William
      TSE
        tnx for coment
          WOW ... very nice.... the curb looks a little sharp....Lovely light..
          Natty
          http://www.rendertime.co.uk
            great exterior !
            I'm wondering about the trees ..
            are they just planes with an opasity map ..? or from a plug-in
            cos the tree shadows are so good to be a shadow map
            keep that up
            Hussam
              Great Job man!
              Cheers,
              Marco
              Workstation Core i7 6900 - 32GB RAM - GeF970
              Dual Xeon E5-2630 - 32GB RAM
                Good job man, a few comments though, i think that the trees are way too big for this image, most of all the big one on the left, its as wide as the arched window of the balcony, u need to displace more the rock wall and its too dark for an exterior, even if there's so many trees around, it aint over the house, at least not all of it.
                Just my 2 cents bro, great image
                Best Regards.
                Jorge Zamudio.
                  Wow! Great job, I only have a couple comments.
                  You should probably bevel the edges of the wall on the left a bit, and add displacement, it's corner look quite sharp. And it should probably be a bit thicker as well so it doesn't get knocked over
                  I think you either need to increase your anti-aliasing settings or check the bitmap filtering because the stone on the house looks a bit jagged and blurry.
                  Your lighting is fantastic, I would love to see your setup.
                  Great job!
                    tnx for u coment
                    2 Hussam_CG
                    trees is a bgraund imaje.
                    2 Dynedain
                    setup from deneb_26.
