So this is the next one I'm working on. Hopefully I'll have better luck with daylight this time
I'm not exactly sure what is causing the noise at the bottom. Should I raise the subdiv. on the vray light i have at the top? Right now its at 15.
Also, I'm going to have to put plants & trees in the 2 areas by the stairs. I will probably end up comp'ing them in photoshop, but have also thought about getting a plants plugin like speedtree or something. For those that have used any of those, what would you recommend for quality, ease of use, & speed?
Thanks!
Thanks!
