-On the first images, youre getting a hard shadow change on the columns, it makes then look like a square column, and not a cylinder.
-on the second image, youre getting a "pattern" on the facade stuff (some kin of courtains?) , there was an interesiting thread on the cgarchitect forums on how to reduce this issue, you could look for it.
Really nice light study..i should say..
i was looking at the detail of the handrail..nice made ! and then i saw the side rail close to the wall...well a bit intersecting everything !!
but anyway, really nice light !
and i guess your vray lights are outside the steal fence ?
Jedi: you are right the columns are not rounded enough by blame of the import of the file from autocad, and the " moire " effect the architect n fact wanted that it's reproduced faithfully.
Oliver: Yes you are right, I don't only have to revise many things but rather also to add many more. Yes the vraylights are outside the steel courtain, as soon I has a moment I will scan a real image of this type of steel mesh.
