Noobie to Interiors-W.I.P.
  • Noobie to Interiors-W.I.P.
    Hi guys,
    I just Started this project and i have a short deadline, was wondering if you could helpe me out.
    All C&C is welcome.
    http://www.imageuploader.net/images/884147CoxInt.jpg
    thanx a bunch
    dReams in diGital
    www.joelRfreeman.com
    www.haysarch.com
    Not sure what you want with this image, but i think it needs a bit more warmth and light, overall it is allready looking good. Are you going to place furniture and add details ? If not i think you should it would make your image come alive. You should also give that painting more thickness, it looks flat.
    Nice work with that cabinet, is that a fotograph or did you put actual 3dstuff in there, to me it looks like a photograph.
    Hope this helps,
    You might also trie to lower the camera or a different lens for a more dramatic effect
    Erik
    A full render queu is a thing of beauty !
      Nice.
      In the main the lighting is good, the only thing that doesn't look right is the hotspot on the corridor leading away from the room. It looks too focused and too circular.
      Other than that I would say the main thing you need to work on is the materials. The biggest culprit being the main beams, and the light fixing and frame that sits/hangs off of them, which are unfortunately the focus of the image. At the momment there is no specular at all, either reflective or fake, so they end up looking as though they are made of matt paper. Even a very slight bump would improve the main beams.
        thank you guys so much, this has helped a tone
        dReams in diGital
        www.haysarch.com
