Playing with glass
  • Playing with glass
    Hi all!!!
    I was playing with glass brick
    The glass is a simple Vray-material
    GLASS MATERIAL
    BASICS
    DIFFUSE
    REFLECT
    INTERPOLATIONS
    EXTERNAL FACES
    INTERNAL FACES MATERIAL (the same glass with a bump map)
    INTERNAL FACES
    FINAL RENDER
    TESTING OTHER MAPS
    GLASS IN SCENE
    OTHER IoR
    GLASS 1,52
    CRISTAL 1,65
    SAFIRA 1,77
    hugs,
    gustavo benites
    Wow that is great. Thanks for sharing!
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
      >jujubee, your avatar is so funny that I cant get used to it.
      I laugh every day when I see it <
        losbellos - my avatar cat is not funny so please do not laugh at her - she is very serious about learning vray...
          Here's my glass block, done as a low-poly solution, its meant to just be a texture on a box, one box per block:
          And here's a sample scene that uses it:
            great job guys, looks good, both of them!
              Dynedain care to share your settings? the low poly solution sounds nice
                No problem, it's pretty simple (sorry but I'm having issues creating screenshots- stupid keyboard)
                Glossiness on Reflect and Refract is both set to 1.0, IOR is 1.6
                Exit color for refract is a dark green, about 0:60:52
                In the reflet and refract slots I have this map:
                In the diffuse slot I have a mask, the mask map is the same image, and the underlying map is just a procedural noise
                In the displacement slot I've dropped this image:
                And dropped a vray displacement modifier on the block
                And I've setup a couple UVW maps to handle the mapping properly
                ehh...what the hell, here's the sample file...you'll probably have to fix the paths to make it work right.
                Glass Block Scene file
                Just a note though, my box is a little wierd in terms of proportions because the designer I had to do this for was specifying a thin profile glass block.
                Oh, and the scene was originally 1.09, but now is 1.46 (on max7) so there are probably optimzations that can be done.
                  sweet.
                    Great Solution Dynedain!!!
                      thanks both for sharing!
                        Great!
                          gustavobenites what do you use inbetween the blocks?
                            hi gustavobenites,
                            i dont understand the reason to imterpolate the refraction since your glossiness 1.0 under refraction. Can you explain that.
                            And also... if you guys like limecat... check this out.
                            http://etudiant.epitech.net/~bret_a/limecat/
                            • #15
                              Excellent glass there guys!!
                              gustavobenites:
                              How is the glass brick itself made? Is it a simple.i.e. A box with the sides extruded twice? and internal face created?
