wip : Interior
  • wip : Interior
    All comments are welcome
    Made with Viz2005 & Vray.
    Zahir3d
    PIXARCHI.COM
    Hi zahir3d,
    I like the look of the space and think with a bit of texture and lighting tweaking it will look great.
    i'd get the metallic frames looking more realistic, make the corb chairs more leathery (a bit of shinyness to them), fix the textures on columns (should it be vertical and smaller?), put some glossy reflections on the floor, displacement on the rug, more light in the scene (maybee some point lights?) and also maybee increase your GI settings or else render at a larger size. I think you need more detail in the stairs as well. You could also try using the camera correction modifier. I think your floor material is a bit washed out also
    Try some of these things out, post the result, and I think some of the more advenced users here will offer some more suggestions
    nice work
      thank you paulison for you constructive comments.
      The Final wip is coming soon
      Zahir3d
      PIXARCHI.COM
        [img]http://www.3dvf.com/modules/wip/popup.php?
        C&C already welcome
        there is a bug render in the right... probably a mesh deformation
        Zahir3d
        PIXARCHI.COM
