Vray 4 beta 1 test render car
  • Vray 4 beta 1 test render car
    A quick test render using Vray 4 beta 1. The CPU render time if I remember clearly was under 1.5 minutes.
    Thank you,
    Garth
    The car is looking good!
    1.5min for that resolution is very quick! What are your hardware specs?
      Thanks man!
      Specs -
      Motherboard; Z10PE-D16 WS, CPU; Xoan E5-2683 V3, Samsung M.2 for operating system, Samsung EEC ram along with two 1080 Ti
      Thank you,
      Garth
        I just did another render. Under 1.5 minutes without denoiser the image looks very clean
        Thank you,
        Garth
          Very nice! Question for you Garth:
          I just bought 2 x 1080ti and was wondering if you us one of them for the viewport, or both for vray rt. Is the viewport that bad, that you need to sacrifice one of them? Thanks!
            Thank you!
            Typically, I use one for the viewport and the other for RT. However, I used both cards for production render. Sometimes I even used both cards when running RT. Keep in mind though that the viewport will lag depending on the file size.
            Thank you,
            Garth
              How do I get my hands on Beta 4?
              Bobby Parker
              www.bobby-parker.com
              e-mail: info@bobby-parker.com
              phone: 2188206812
              My current hardware setup:
              • Ryzen 9 5900x CPU
              • 128gb Vengeance RGB Pro RAM
              • NVIDIA GeForce RTX 4090 X2
              • ​Windows 11 Pro
                Just log in your profile in chaosgroup.com and you should see it in the download section.
                Aleksandar Mitov
                www.renarvisuals.com
                office@renarvisuals.com
                AMD Ryzen 9 9950X 16-core
                96GB DDR5
                  looking great !
                  I liked the car paint..the only thing that need work is the background as it is too blurry now imo
                  Simply, I love to put pixels together! Sounds easy right : ))
                  Sketchbook-1 /Sketchbook-2 / Behance / Facebook
                    Si. I didn't realize that til now. Thanks for pointing that out.
                    Thank you,
                    Garth
                      That is the first place I checked, however, I don't see anything there.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        You have to register for it, which I just did.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          You may need to send Chaosgroup support team an email for access.
                          Thank you,
                          Garth
