hi
very nice job
but the size of the trees reflecting in the glass (hdri?) is a little bit out of scale
these trees seem to be automn's tree, but the ones you put in the street are very green
Oh My!! this is awsome!! I usually do a lot of exteriors but none has this beautiful day light effect, can u please be so kind to elaborate on the lightning setup? or if you are so amazingly kind to share the file that would help me so much to progress on my work, and of course i wouldn't share it, or make anything to the file other than studing it....
There is really no particular lighting setup, i always go after photo.
There is one direct light with m=2, gi environment=light blue=1, hsv mapping=0,9, indirect ill=1,2/secondary b=1.
And obviously some touches in PS. Curves & color correction + slight
glow effect on highlight areas.
model looks good. but it could do with some life added to it.
attention to detail
Of course if there is no budject then fine. But you could do with furniture inside, and all the walls look very flat. Needs some post work doing on it. Small blemishes, some textured overlays. A wall in reality would never be like that.
Also in terms of the photomontage, try adding some gradients. light over a building wont be constant.
These are small things that wont take long.
