Vray for Revit -VRScan
  • Vray for Revit -VRScan
    today i tried to use the VRScan trial but its not working or im doing something wrong. I downloaded a VRscan and replaced the current material of the object with the downloaded VRScan. When i try to render it, it doesn?t work and stops .
    Im totally new with Vray for Revit and would like to know what i am doing wrong.
    Best regards
    Dave Click image for larger version  Name:	pic1 (1).PNG Views:	1 Size:	40.9 KB ID:	993826
    Dave, can you give us more details on this? Is there an error message? How does the vrscan material appear on the rendering?
    Ana Lyubenova
    Product Manager
    www.chaos.com
      it looks like on the screenshot below. I am using an EDU Version of Vray and wanted to try the vrscan trial. Thanks for your Response!
        This is because you are using an EDU license for V-Ray for Revit and a trial for VRscans. To use VRscans, install the trial of V-Ray for Revit, so that both licenses are of the same type.
        Once your trial is over, switch back to the EDU license.
        Ana Lyubenova
        Product Manager
        www.chaos.com
          Ok thanks! That was a stupid move. Because i already bought the EDU license without utilizing the Trial license... Do you know if there is a Chance to pause the EDU license until the Trial Ends?
            Try to contact education@chaosgroup.com and ask them.
            Ana Lyubenova
            Product Manager
            www.chaos.com
              Thank you so much for your Support. Really great how fast you responded and helped me!
                Thank you! In case you experience any other issues, we are here ; )
                Ana Lyubenova
                Product Manager
                www.chaos.com
