Mobo for Ryzen 2700X?
  • Mobo for Ryzen 2700X?
    Hi guys
    So if I'm planning on building a modest multi-GPU rig, what mobo can I get if my CPU is a Ryzen 2700X?
    I've had a quick look and seem most of these only come with 2 or 3 slots for gpu. I'd probably only have 1 GPU in there, but would like to know I have the option to add more later
    Looks like the X470 chipset boards are the new ones
    Or should I be looking at something else?
    Budgets are tight!
    Kind Regards,
    Morne
    the 2700X has 24 PCIe lanes, and in many Mobos 4 of these are used by chepset for things like M.2 and other devices
    So you are only left with 20 PCIe lanes, on 2/3 slots
    For optimal results you should run your cards at x8 at least, x4 will affect loading your scene into VRAM, but mostly you will be fine with 3 cards
    X470 Boards are very cheap, I would recommend the Maximus Hero which is at 250 USD
    It is probably the best/most expensive Board for this platfrom, and it should handle 3 cards without issues in future (x8,x8,x4)
    If you want something cheaper, see the X470 Strix at 160 USD, but for 3 cards and considering how cheap boards are for this platform go for the Maximus Hero
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Thanks for that.
      Do you get boards that support 4 or more GPUs for the 2700X?
      Or do I need to look at a different CPU then?
      Kind Regards,
      Morne
        I don't think there is a board that has more than 3 full sized, PCIe slots for this platform
        An affordable solution for 4 GPUs would be 1920X(very cheap now) and something like X399 Gaming pro Carbon
        Or look for an i7 6850k and an X99 board that has 4 PCIe slots, but these are quite rare now
        With TR, you will have up to 5 slots(with a specific Mobo), so you can fit 3 cards on Mobo and maybe use 2 Ryzer cables for the other 2 cards or just use 4 cards directly on board
        On Intel's side, X299 for example , you can have up to 7 slots and again you can only fit 4 on Mobo, so if you want to make use of all slots you will need riser cables(Anything above 5 cards will not work out of box, you will need to do some work)
        Then with 2 Xeons, you can have up to 7,8,10 and 11 slots without the need for risers
        With Thunderbot 3 support on some high end Intel Mobos, you should be able to use eGPUs(up to 4 through an external box)
        There are more ways to run multiple cards, but I would not recommend, like PCIe clusters or running cards on x1 slots, things get complicated and there will be a performance hit
        Muhammed Hamed
        chaos.com
          hmm there is a 1900X as well, that is an 8 core, the cheapest TR if you can find it
          Muhammed Hamed
          chaos.com
            Yeah I don't think I will have budget for a Threadripper. It's a modest PC that will start with probably only 1 GPU
            Entire budget for pc (including screen, keyboard, mouse and Win 10) is only around 2250 Euro
            Kind Regards,
            Morne
              Threadripper 1900X >> 350 Euros
              MSI X399 Gaming Pro Carbon >> 320 Euros
              32 GB DDR4 RAM 3000 Mhz >> 220 Euros (must be 4 RAM stick for quad memory channel)
              Be quiet Dark Rock Pro >> 80 Euros
              Be Quiet Silent Base 801 >> 140 Euros
              Be Quiet 1000W 80 plus gold >> 220 Euros
              970 EVO 500 GB >> 110 Euros
              Seagate Barracuda 4TB >> 80 Euros
              1070Ti 8 GB >> 500 Euros
              This should be cheaper than 2k Euros, so you still have money left for monitor, keyboard, windows and other things
              And btw, no cheap parts as everything is within your budget,
              this system can equip up to 4 cards whenever you think about adding more, you don't need to change power supply
              Muhammed Hamed
              chaos.com
                On that X399 board, will any of these also work?
                Threadripper 1950X
                Threadripper 2920X
                And between those 2 CPUs, which is is the better choise (also taking into consideration, speed, heat, power usage etc)
                And then, between a 1900X and a 1920X, how much difference are there, seeing that the 1920 is a lot more expensive than the 1900
                Kind Regards,
                Morne
                  Threadripper 1950X
                  Threadripper 2920X
                  All TR CPUs should work just fine on this board, so the 1950x, 2920x, 2950X should be all fine
                  Even the 2990wx and 2970wx will work, but without OC
                  And like any Mobo, you should update the bios when you get this Mobo
                  The 1950x is a better value, and it will be faster in CPU rendering.. it is a very good deal @600 Euros
                  the 2920x has a slight advantage in single threaded tasks(Can turbo up to 4.4 GHz or so with XFR2) while the 1950X can Turbo up to 4.1/4.2 I think
                  I recommended the 1900X for the budget you wrote above, the 1920X should be like 150-200 more Euros and it has 4 more cores
                  It is all about how you will use your system really, if you will be doing GPU rendering most of the time and your are tight on budget the 1900X should be your choice
                  If you will be doing any CPU rendering as well, you might want to look into how much you gonna spend really
                  Talking about my experience personally, 3 weeks ago I bought the 1950X at 600 Euros with the exact same components I wrote you above
                  Same case, Same CPU cooler, Same Power supply(850watt though)
                  The board is an Asus X399 Strix though, but you should go for the MSI board so you can fit 4 GPUs in future
                  Muhammed Hamed
                  chaos.com
                    The RAM I used is 32 GB 4 sticks x 8GB Gskill TridentZ RGB @3200 MHz
                    not the cheapest RAM, but TR benefits from higher memory speeds and I have been using this RAM for many other builds. It works nicely
                    About the Case, it has a built-in fan hub like what you see in the first picture, and it comes with 3 Silent wings fans, which are silent and still has an amazing peformance
                    I dislike RGB, and I'm not willing to waste my money on it really .. Same fans in the case, are used on the CPU cooler, the Dark Rock Pro 4.. I have used this cooler in many builds, works nicely/silently and you can overclock with it to 4 GHz without issues
                    Muhammed Hamed
                    chaos.com
                      If I eventually stick 4 GPUs in there, where do I put my M2 drive?
                      Kind Regards,
                      Morne
                        Morne You don't install the M.2 drive in PCIe(anymore)
                        This board has 3 mounts for NVMe, between the PCIe slots(Same for most other boards, released in the last 3 years) .. See number 10 in the picture
                        Muhammed Hamed
                        chaos.com
                          You won't be able to install the Wifi card though, with 4 GPUs, which I think you will not mind much
                          Muhammed Hamed
                          chaos.com
                            Isnt that last GPU slot mostly useless, because if you plug in a card there, you can't plug any cables into the headers at the bottom?
                            Kind Regards,
                            Morne
                              Nope, I have done 4 GPUs on variety of Mobos including this one
                              you can place a card in there, on top of the cables, the cables will bend slightly but you should be totally fine(MSI knows about this issue and solved it long time ago)
                              This last slot actually allows you to use bigger cards, (more than 2 slots in width) without issues as there is no other slots below it
                              So it is very common that people use this slot specifically even if they only have 3 or 2 cards only
                              Muhammed Hamed
                              chaos.com
