Friend of mine just recieved a workstation built by a pc company to his spec. It was crashing, and he discovered they had undervolted it. At stock voltage it hit 68 degrees and starts throttling. Vrms get extremely hot too. Spec is:
Coolermaster sl600m case
Corsair h150 pro cooler
Asus prime x399a mobo
128gb corsair vengeance 2933 ram
He suspects he skimped a bit on the motherboard as the vrm cooling isnt great.. But why is the cpu overheating? Thats a triple radiator cooler, so should handle it id guess. Does seem strange the cooling head is square, so leaves a few mm of cpu bare on either side.. But apparently its compatible..?
Case is a "chimney effect" cooling one, so 3 fans at top blowing out, and 3 at bottom suckin in, rest of case no vents. Radiator has been tried both top and bottom of case. Id be fiddling with it myself, but im 3000 km away.
