New workstation :New Threadripper 3960X or 3970X or Ryzen 3950X
  • New workstation :New Threadripper 3960X or 3970X or Ryzen 3950X
    Okay finally time to upgrade my workstation. I was waiting and waiting for 7nm AMD and here it is. Now the problem which one to go with.
    For me it's not only rendering but lot of modeling and multitasking (rendering, zbrush sculpting at the same time etc.) Also cloth and particle simulation. SO I need one powerful workstation that can do it all
    Is it worth getting the 32 core beast 3970x or a bit overkill and go with 24 cores as it's 100mhz (3.8Ghz) base clock faster which is important in 3dsmax as it's one core app.
    I'm not sure about Ryzen 3950x as I read that it will require water cooling and because if Threadripper size I assume air is still good and quieter option.
    Whats your take an all this?
    Luke Szeflinski
    :: www.lukx.com cgi
    I vote for 24cores. Already bought 256gigs
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
      Originally posted by Paul Oblomov View Post
      I vote for 24cores.
      any reason why 24 and not 32?
      Luke Szeflinski
      :: www.lukx.com cgi
        Cheaper. Faster one threaded
        CG Artist
          It`s not going to be faster one threaded. Both can go up to 4.5Ghz. In single threaded app, cpu will be looking for best core to run the thread on. And it`s not going to be at 3,7 VS 3,8, but much higher, possibly near to 4.5ghz....
          Noemotion.net - www.noemotion.net
          Peter Sanitra - www.psanitra.com
          Noemotionhdrs.net - www.noemotionhdrs.net
            Then, cheaper
            CG Artist
              i am very interested to see how the 8 channel chips compare.. nothing is certain at the moment, but there is definitely a chipset for threadripper coming with 8 memory channels (wrx80) and presumably chips specifically for that chipset. i assume (and i could be wrong) that the 48 and 64 core threadrippers (due in jan next year or so) will be 8 channel, since 4 channels is already rather feeble for a 32 core chip.. makes sense that the newer higher core models will have to address this.
              zen2 seems to work very well given the limited bandwidth (they have tons of cache) however there are limits, and more is better.. so maybe the 8 channels will perform noticeably better than simply having more cores. of course, clock speeds might be much lower...
              anyone from Chaos care to give an opinion on zen2 vray performance? is it limited by memory bandwith significantly on the higher core models? or does it generally play well with the large caches available?
                Ill wait for 3990 coming in January
                Martin
                http://www.pixelbox.cz
                  +1 for waiting for 64 cores.
                  Website
                  https://mangobeard.com/
                  Behance
                  https://www.behance.net/seandunderdale
                    I saw a review on 3950x in youtube channel,the benchmark result shows that 3950x slower than core i9-9980xe in Vray and Corona
                    It's a little bit confusing to me since 3950X beats 9980xe in Blender Cycles render..
                    Can anybody give some info about the benchmark result? Does that means intel chip is better than zen2 in Vray or Corona?
                      Yes, at least in Vray.
                      Website: http://www.3drenderandbeyond.com
                      Shop: http://www.3dtutorialandbeyond.com/
                      FB: https://www.facebook.com/3drenderandbeyond/
                        I would not invest into 16 core nowadays
                        Martin
                          I am interested in your choice,are there any better options for you to build a powerful workstation?
                          It will be really appreciate if you can share your experience.
                            32 threads just dont cut it for me. I am not surprised intel beats amd on that front plus they have a lot better memory handling. Iam reliant on cpu because our projects use a lot of memory. Therefore i go for highest thread count machines with good price per core ratio. TRs are great, but the lower end ones are easily replaced by intels. If you have good enough budget, go for 32 core at least
                            Martin
                            • #15
                              Review are out, performance of 3970X is just nuts
