So the new Threadrippers are right around the corner and I'm contemplating upgrading my current workstation. What do you think would be a better choice for rendering in Vray? The 24-core Theradripper 3960x or one (or two) RTX 2080 Ti's? Pros and cons? The last time I've been experimenting with GPU rendering was a bit over a year ago and my overall impressions were not that great. There were important features that were still not supported and I've also been experiencing some strange behaviors/bugs. Is this still the case? CPU rendering has been rock-solid for 99% of the time. Any reasons to go with GPU rendering this time?
24-core Theradripper 3960x or a GPU-based workstation with RTX 2080 Ti's?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
80% arch-vis (of which 70% exterior and 30% interior). The remaining 20% is product-vis. So far I've never exceeded the 32 GB of RAM on any project. Normally my RAM usage during heavier exterior renderings hovers around 10-12 GB, maybe 15 GB in some extreme cases.Aleksandar Mitov
96GB DDR5
I would add two headless 2080Ti with NVLink . Use them only for renderig without a monitor.
And your 1080 Ti is doint the viewport work.https://linktr.ee/cg_oglu
Ryzen 5950, Geforce 3060, 128GB ram
How fast is a 2080 Ti at rendering using RTX (Vray Next Update 3)? Are there any benchmarks that I can see comparing it to a CPU such as Threadripper 1950x/2950x?Aleksandar Mitov
96GB DDR5
- Likes 1
Originally posted by Alex_M View PostHow fast is a 2080 Ti at rendering using RTX (Vray Next Update 3)? Are there any benchmarks that I can see comparing it to a CPU such as Threadripper 1950x/2950x?
Depends on how much geo and how mutch shading work has to be done.
CPU could be faster on some and on some RTX will be faster. Depends also on how much hardware you throw at it.
Its much asier to upgrade GPUs.
I fear you have todo your own testing.
https://www.chaosgroup.com/blog/prof...idia-rtx-cards
https://www.chaosgroup.com/blog/v-ra...for-nvidia-rtxhttps://linktr.ee/cg_oglu
Are there still "asterisks" with GPU rendering? Like unsupported features, textures, shaders etc? Also, how am I supposed to make a decision when the Vray benchmark renders two different scenes with CPU and GPU?Am I supposed to blow a few thousand $ on new hardware and test all of this for myself?
Aleksandar Mitov
96GB DDR5
GPU doesn't support all features (yet). Most important ones are there, though.
Not only vray features are missing. Other plugins might also not render as expected.
GPU's can be impressively fast on many scenes especially now with rtx support.
You're mainly rendering stills right? So rendertime isn't that much of a problem probably.
Well, at least not the "I gotta get 2000 of those images rendered within a week" kind of problem.
Getting stuff to work well on the gpu (i.e workaround missing features / fitting the scene in the vram) can take some hours.
For me (who does 100% animation) it makes total sense to put this effort in if I can render 200-300% faster afterwards.
But if I'd do only stills I probably wouldn't care.
You decide between stability and being able to throw anything at your scene vray has to offer.
And much faster rendering but less stability and fewer features.Last edited by Ihno; 26-11-2019, 03:34 PM.German guy, sorry for my English.
The AMD three 64-core, 128-thread CPUs are supposed to trickle down to the consumer in 2020. It is a CPU vs GPU race.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
- Likes 1
Originally posted by Ihno View PostGPU doesn't support all features (yet).
