4 x 2070 Super or 2 x 2080 Ti for GPU rendering?
  • 4 x 2070 Super or 2 x 2080 Ti for GPU rendering?
    Since both options cost roughly the same, looking purely at performance, which will be better, 4 x 2070 Super's or 2 x 2080 Ti's? I am aware that 2070 Super has 8GB of VRAM while 2080 Ti has 8GB.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    According to https://benchmark.chaosgroup.com/next/gpu, 2080ti x2 is roughly as fast as 2070 x3. Keep in mind the benchmark is still RTX OFF, where V-Ray in Max in Maya is RTX ON.
    I would still go 2080ti, as it has 11GB memory and you will save some PCIe slots for the future upgrades.
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      I should hasten to add that regardless of the RTX option, the plain CUDA engine hasn't gotten slower, on the contrary!
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        2x 2080tis as they use nearly double the NVlink bandwidth, if you will be using that
        And 2 cards are easier to cool, you won't need blower style cards for this, and you can go for Triple-fan design
        2 cards = upgradability in future
        Maybe if you won't use NVlink or the extra VRAM and you won't add more cards any time soon, consider 4x 2070s
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          Good points. Thanks for the info.
          Aleksandar Mitov
          96GB DDR5
            I am curious to know what will happen with this out of core memory when it comes... how that will affect the equation.
            http://www.jd3d.co.uk - Vray Mentor
