New Ryzen 9 3950X build suggestions/recommendations
  • New Ryzen 9 3950X build suggestions/recommendations
    Hi Guys
    I'm looking to get another system, anything you would change/add/remove and why?
    AMD Ryzen 9 3950X
    NZXT Kraken X63
    Asus X570 Crosshair VIII Hero
    NZXT H710i
    Corsair HX850i 850W
    4 X 32GB Ram, but havent decided what make and speed yet!
    1 TB M2 Drive, but havent deciced what make (Its just for OS and Programs, all my work is in the cloud/NAS so dont need local storage for that)
    GPU I will use my existing 1080TI and wait it out to see what the 3080 Ti vs Big Navi II offers
    I will remove the 1080 Ti and stick it in another system and replace it with 2 X new GPU's depending on what the new versions bring to the table when they are released.
    Kind Regards,
    Morne
    Hey Morne
    The build looks good!
    I would go for X570 Aorus Master board, if it is cheaper.. but it doesn't matter much honestly, specially if you like Asus
    Cool case as well, but go for the none i version.. called H710, should be a bit cheaper without their smart device
    Make sure your RAM is 3200 MHz and CL16 ...and if you don't need 128 GB RAM, I would recommend you pick 4x 16GB .. These Dims are much faster than any 32 GB Dims, look for CL14 3200 Mhz
    For the drive check out Samsung 970 EVO, should be like 250 USD or so for 1 TB
    And your power supply should be plenty, even when you have 2 GPUs
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Thanks Muhammed_Hamed
      What's your impression on these?
      Corsair Vengeance LPX 4x16GB DDR4 PC4-25600 CMK64GX4M4C3200C16
      Kind Regards,
      Morne
        Looks good!
        I personally prefer Gskill TridentZ ,it is what I use for my builds.. but feel free to go Corsair
        Muhammed Hamed
        chaos.com
