Sometimes GPU makes more sense than CPU, but other times not so much. I wish I could do everything in GPU, but it is usually a hit/miss.
New Workstation
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Originally posted by Neilg View Post$1,750 for a machine which is half the CPU rendering speed as one at $20,000Last edited by dlparisi; 28-01-2021, 05:15 PM.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Originally posted by glorybound View PostI can't get what I want for much under $20,000. Basically, 3090X Ryzen 32 core, 128Gb of RAM, and 2 RTX 3090's. Is this what I should expect to pay for a decent machine?
Your comparison and advice is very bad :I
3990x scores close to 70k in vray bench, 3950x is around 18k
And like what Super Gnu said, it is 7000 Euros without GPUs.. It is actually a very good value overall in many ways
Originally posted by Neilg View Postit's all your eggs in one basket if you get a hardware failure.
Hardware is very reliable nowadays, specially that he is getting a prebuilt from Maingear.. once it is setup there is no reason to think this is gonna fail
Originally posted by Neilg View PostThe 3950x is half the speed as the 3990x - so 2 of them in DR should be pretty close to the same, except you've spent $1,400 on cpu's instead of $4,000
https://benchmark.chaosgroup.com/v5/...ng=desc&by=max
and I wouldn't compare DR to local this way.. This is not how it works, and scaling is not 100% linear
This is not just about final rendering, look-dev is still part of the equation ..
glorybound
You gonna need 4 machines at least with 3950x with DR to beat a single 3990x in final rendering, and for Look-dev and IPR the 3990x comes on top
@7000 Euros without GPUs, the 3990x is a much better choice than having 4 machines and dealing with DR
And @ 12k Euros with 2x 3090s with a custom loop for CPU and GPUs.. this is a very good deal, considering how you use GPU rendering on some projects. This is how I would spend my own money
I get commissions building high-end CPU and GPU rendering machines, it is fucking nuts to tell a client to invest in 6x 3950 machines instead of a single 3990x machine(to save a few hundred bucks supposedly)
Even the technical folks who are used to DR rendering and whatnot.. This haven't happened a single time, everyone goes Threadripper now..These CPUs changed the industry in many ways
- Likes 1
Originally posted by dlparisi View PostIn what universe is this just a "decent" machine?Bobby Parker
phone: 2188206812
- Windows 11 Pro
A little...
Originally posted by Neilg View PostIt's 8x $1500 machines. few are rendering full time if they need to, the rest are workstations and going at night. This is 6 people in Miami with multiple jobs on at once.
I think the NY studio has 30 of the same machines.
Edit: i wasn't trying to bang on about that, i was just saying - get a powerful desktop, but maybe ease it back to mid power range - 10k even seems ludicrously high and get a second which can render while you work as a backup. If one goes down you're not totally screwed.
Originally posted by Muhammed_Hamed View PostYour comparison and advice is very bad :I
That is not true,
not sure what the 3950 gets but i know the 3990 is so conservatively clocked (unlike the other models) that its really the only zen2 chip which shows decent improvements with PBO (even allowing 350watts up from the baseline 280 makes a huge difference) . if i had a better motherboard i could probably hit 100k in vray benchmark, but my vrm overheats if i push it too far, and the wattage through that little slab of (very expensive) silicon would make me a bit nervous! .Last edited by super gnu; 29-01-2021, 02:50 AM.
super gnu I was talking about Vray 5 Benchmark scores, I had a link in my message. 100k in the old benchmark is like 60-65k in the new one
The ratio is correct though, he will need at least 4x 3950x in DR will be able to match/beat a single 3990x
Also part of the reason I recommend the expensive boards above(compared to the one he had in the screenshot), either the creation or Zenith board I'm able to run all cores at 3.5 and 3.6 GHz, but best is to do the OC per CCX(with PBO off) and have a single high CCX at 3.8 or so for single threaded tasks..
You gonna need to set the voltage manually as well (to control the heat)
In every build with this CPU, I have been limited by thermals .. I think a custom loop would be handy in this case
ahh ok, yes i am indeed on an old benchmark version.. doh.
and yeah, my cooling system is monstrous (2x mora3 radiators and dual pumps) but the cheapy asrock creator motherboard, despite claiming a 1000w vrm, actually downclocks cpu if it goes much over 400w for a sustained period. -fine for literally any cpu apart from this one.. - im in the process of getting custom vrm waterblocks machined.. might get a bit more "go" out of it yet.
given how fast it is though, i cant quite justify spending on a new mobo, and its rock-solid stable within its limits. dont think ive had a pc crash since building it, which is, frankly, unheard of.
p.s. sorry Bobby for the thread hijack... tldr: get a 3990xLast edited by super gnu; 29-01-2021, 03:25 AM.
Each time I’ve upgraded my machine, I’ve pondered whether to continue using the old machine as the main machine and have the new, more powerful machine with its faster CPU’d as the one for sending renders to....
I’ve never actually ended up doing that (in my case I have two identical machines right now), but it does seem to make some sense (if your display and viewport performances have never been a problem).Jez
3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
---- Updated 06/09/23 -------
Originally posted by JezUK View PostEach time I’ve upgraded my machine, I’ve pondered whether to continue using the old machine as the main machine and have the new, more powerful machine with its faster CPU’d as the one for sending renders to....
i could maybe understand swapping to the slower machine to work if you have a big render to get out quick.. but in that case id probably be putting both machines on it and going out for lunch, or to bed.
Part of getting stuck to GPU rendering, I can have a 5k render on GPU and my machine still would be usable fully (using a different GPU for monitors/viiewport)
I have a 3070 and 3090 now, Only using the 3090 for rendering...
Even for CPU rendering, I leave 4 threads off so that I can do modeling or Nuke.. leaving 4 threads (2 cores off) barely affects rendering speed
And nice build you have super gnu I think we talked about your build in the past?
If we did, then I'm sure I mentioned VRMs and Mobo choice for this CPU..
Even back at the 2990wx, High-end Mobos were necessary .. Creator and Zenith as well
