NVlink and 2 different 2080ti
  • NVlink and 2 different 2080ti
    is it possible to use nvlink between 2 different brand 2080ti?
    e: info@adriandenne.com
    w: www.adriandenne.com
    I have two 2080 Ti from different brands with a nv bridge running... and it is stable..
      awesome thx for reply buddy
        yeah so incase anyone tries this, make sure the heights of the multiple cards are the same otherwise nvlink isnt going to connect, unless anyone knows otherwise?
          autsch... ok, I think I was lucky then .. I took the first card I could get as the second card ... I would believe height is the same everywhere
          and now? are there flexible bridges available ?
            Different cards will have different heights, except the ones that use the FE PCB (very rare on the newer beafy cards)
            There are no flexible bridges around as far as I know.. you will need 2 matching cards for NVlink (unless you know 2 cards that use the same PCB, so they will be the same height)
            Muhammed Hamed
            V-Ray GPU product specialist
            chaos.com
              I didn't know it. I really had luck to get a second card with the same height...
                yeah i could had got an identical card but chickened out at last minute because the other bidder was clearly buying for mining, so instead I got another and had this problem...why they dont make flexible cable versions when they know most cards are different heights is a bit annoying//. I mean the gigabyte 2080ti and the gigabyte windforce version are different height for crying out loud
                  never opened such a bridge, don‘t know, if this is only a one to one cable connection or if there is a chip in between…
                  https://www.ebay.de/itm/1PCS-Flexibl....m46890.l49286
                  don‘t know if this is something usable or not..
                  maybe you can easily open your bridge and see if it could work without the box.. just a helpless idea…
