Dark Hero BIOS settings for Ryzen 9 5950X
  • Dark Hero BIOS settings for Ryzen 9 5950X
    Hi Guys
    If I'm not planning on overclocking, are there any specific settings I should be paying attention to, or can I basically set everything to default in the BIOS?
    ASUS Dark Hero, AMD Ryzen 9 5950X
    Also, do you guys install all the utilities and monitoring that come with the board, or do you prefer only the chipset drivers?
    Muhammed_Hamed
    Kind Regards,
    Morne
    Hey!
    Sorry for the late reply, it has been a busy week for me
    Default settings in Bios, then enable DOCP and choose the profile for your memory. Save and reboot
    This is all what you need to do, there is a also a way to get better performance with some minor tweaks, called curve optimizer
    https://www.youtube.com/watch?v=dfkrp25dpQ0
    This is not needed to do, but it is very easy and gets you a better single and Multi-core scores, specially that you have good cooling in your case
    Only Armoury Crate, it has everything you need to install after like drivers and utility software
    Here is what I did, greyed out means I checked and installed it
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Nice one, thanks!
      Kind Regards,
      Morne
