Gpu system recommendations for 2022
    Hey Olaf,
    Originally posted by dimension3plus View Post
    Why did you choose the 5990x instead of a Intel® Core™ i9-12900KF ? Is the i9 not better for single core? I mean working with 3ds max is mostly single core in my experience.
    I have been using this CPU since day 1, it has not been a great experience. DDR5 memory is very expensive, and very rare.. impossible to find 128 GB kits, 4x 32 GB and it doesn't offer anything better than DDR4 performance wise
    Also the power draw is nearly double that of the 5950X, which means you need a good board for the 12900k around 400 to 500 Euros (also boards are expensive and rare) and a good cooling solution
    The 5950X is very efficient on rendering, you will be totally fine with a 200 Euros board like the B550 Tomahawk.. and doesn't really need an extreme cooling solution
    Now about the Single threaded performance, the 5950X is great. Out of box it goes above 5 GHz, I have been using that for more than a year and I'm totally happy with it
    The 12900K is faster on single-threaded, a tiny bit faster that you would really need to scientifically measure the differences in Max
    My hardware seller currently only has 3 different RTX 3090 on stock, which do you think is the best choice for a 2 GPU system?
    Sadly all 3 are not great, I would go Ventus or Palit Gaming Pro if you cannot find anything else.. I talk about the good GPUs in this post
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Thanks for your answere!
      Olaf Bendfeldt
      3D-Artist
      dimension3+
