New PC Workstation
  • New PC Workstation
    I'll have to change my PC configuration, but I lack competence in choosing components (motherboard, memory, graphics card brand, power supply, cooling system) that are 100% compatible with each other. (speed, temperature, consumption...)
    I would like to start with 1 RTX3080ti graphics card and then add a 2nd one a little later.
    Can you give me some examples of configuration or give me (if it's allowed on the forum) some internet links of high-end PC specialists for 3D ?
    Thank you very much.
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.571 + V-Ray 7.00.03
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7.1
    GeForce Studio Ready Driver Version 572.16​
    theres a few good threads in this section with some great advice...which i took with my recent new pc.
    'pcpartpicker' website can be useful for picking compatable components.
    e: info@adriandenne.com
    w: www.adriandenne.com
      https://www.cgdirector.com/ is a great starting point. They have a simplified PC builder where you set your own budget etc. Highly recommend!
      My Artstation
      Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
      Sun Tsu
        Hello DCHA34
        Here is a good value build you can rely on, minimum RGB
        Asus X570 Dark Hero
        Ryzen 9 5950x
        Bequiet Pure Loop 360 cooler
        Bequiet Silent Base 802 case
        Bequiet Dark Power Pro 1200 W
        4x32 Gskill TridentZ Neo 3600 CL18
        Samsung 980 Pro 1 TB
        You can add GPUs and more storage to the build as needed. Check out this post here on the good GPUs, although you might not have the luxury of choice
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          Hello to all,
          thank you very much for your answers.
          I will be able to start studying my new configuration.
          Chaos Vantage 2.7.1
