Power Supply
  • Power Supply
    Would a 1500W power supply be able to power two RTX 4090s? I know technically it would need 1600W.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    It should be more than enough, specially from a reputable brand like Seasonic, Corsair or EVGA
    Technically each 4090 needs 450 watts, plus say 300 Watts for the rest of the components. That is 1200 Watts in total. Some spikes happen(usually in games) the GPU could peak to 700 Watts momentarily, a 1200 Watts good power supply will handle that easily
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      That is good to know; thank you!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        How about a 1200W power supply?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          should work just fine as long as it is from a good brand
          Make sure it has 8x 8 pin GPU cables for the 2x 4090s
          Best,
          Muhammed
          Muhammed Hamed
          chaos.com
            Perfect! it is a Corsair 1200. I'll give it a try. The 4090 installed has the four 8X8s going down to two 8X8 with a splitter cable. This one is working fine. For the second one, I'll have 8X8.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Or is a splitter a bad idea on a power supply to the graphics card? This one seems to be working fine.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                As long as you didn't add those splitters yourself, the HX1200 Watts should come with 4 cables ending at 8x 8pins. It should handle 2x 4090s
                Muhammed Hamed
                chaos.com
                  It seems that each 4090 needs four cables ending at 8X 8pins. The one I have has one cable coming out of the 4090 and splitting it into four. Then he has the splitter, returning it to two 8X 8pins. I don't think the power supply has eight 8X 8pins available. I ordered the splitter, so we'll see if that works for the second one as it does for the first one.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I have both 4090 working now. The guy who built this PC did something weird with the cable management. The one 4090 with his cable took 4+ hours, and the two with the proper cables took 15 minutes.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Both of the GPU's fans are spinning, so I assume they are both working; however, one is showing 0% usage.They both show up in V-Ray.
                      Click image for larger version  Name:	image.png Views:	0 Size:	100.1 KB ID:	1211171
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I think I am fine. The V-Ray stats show both being utilized.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Congratulations!
                          Give it a try with the new build of V-Ray bench and share the results here please.
                          about Task Manager, it doesn't show anything on the second GPU, see my post about GPU monitoring here
                          Muhammed Hamed
                          chaos.com
                            Should be fine, 4090s are very effecient on GPU power draw. much better than the 3090s
                            I recommend running the CUDA mode in Benchmark for 10 minutes(see the loop option) just to make sure it is all stable and working fine
                            Temperature should be below 80 degrees
                            Best,
                            Muhammed
                            Muhammed Hamed
                            chaos.com
                              Here is CUDA
                              https://benchmark.chaos.com/vray/v6/...pu/scores/9242
                              Here is RTX
                              https://benchmark.chaos.com/vray/v6/...pu/scores/9244
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
