Looking at a new render setup and appreciate any advice. I came up with these scenarios (based on DIY component build cost and published Vray scores):
Here's how I see it:
Option A
Option B
Option C
PS: I know the RAM isn't equal - I could go to 512GB RAM in the workstations for ~$1600 more each and I probably would. 256 is enough for what I've been doing, but nice to have some cushion. The larger amount in the Epyc server is just to fully populate all the channels for performance and seems like the thing to do with so many cores.
Option | Configuration | Cost (ea.) | Vsamples (ea.) | Qty. | Cost (Total) | Vsamples (Total) |
A | Server: Dual AMD Epyc 9755 128-core, 1.124TB RAM | $35,000 | 354,400 | 1 | $35,000 | 354,400 |
B | Workstations: AMD Threadripper Pro 7995WX 96-Core 256GB RAM | $17,000 | 188,200 | 2 | $34,000 | 376,400 |
C | Workstations: AMD Threadripper 7980X 64-Core, 256GB RAM | $11,000 | 130,200 | 3 | $33,000 | 390,600 |
Option A
- Most power efficient / lowest power bill over time
- Least administration (just one node)
- Highest scaling density (3X more power in a rack)
- Highest up-front cost
- Lowest aggregate performance
- No redundancy (one node goes down and I'm incapacitated)
- Dedicated system / not practical for swinging to workstation use
Option B
- Somewhat between A & C, but more like C just costlier​
Option C
- Least up-front cost
- Highest aggregate performance
- Most redundancy (three nodes, so can limp by on two if one goes down)
- Easier self-support (can transplant parts from working system to troubleshoot hardware issues)
- Flexibility of potential to be used as workstations part-time
- Less power efficient / higher power bill over time
- More administration (multiple nodes vs one big node)
- Low scaling density (takes 3X physical space to achieve same performance as Option A)
