New workstation advise
  • #16
    There is nothing really as maximum..
    What I'm trying to say is to not to spend money on high-frequency memory which could be a waste(if you find 5800 memory and 7000 memory, pick the 5800). There are some low-latency high speed kits that are expensive, they could work fine for gaming, it will be hard to make them stable for rendering if all 4 memory slots are occupied
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    • #17
      Best,
      Muhammed
      5800 and 7000 is it a figure of the RAM speed? or do you mean if I have found 2 memory 1 is 5800MHZ the others 1 is 7000MHZ, choose the 5800MHZ one, is it correct?
      In my quotation, I have 2x32GB, which mean it is occupied 2 slot only, which mean it will be more stable?
      Jackie Teh
      3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
      AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
      Website: https://www.sporadicstudio.com
      Email: info@sporadicstudio.com
      YouTube: https://www.youtube.com/c/SporadicStudio
      • #18
        Best,
        Muhammed
        Is this mean no need to buy AMD EXPO RAM if I am not doing overclock? because i don't like to do overclock
        Jackie Teh
        • #19
          Yeah it should
          Muhammed Hamed
          chaos.com
          • #20
            It is needed even if you don't overclock
            Muhammed Hamed
            chaos.com
            • #21
              Yeah it should
              Finally I am more clear, thank you for helping me.
              Jackie Teh
              • #22
                Hi jackieteh
                Upgrading from Threadripper 1950X to Ryzen 9950X is a big upgrade, you will notice a difference in pretty much everything.
                Your build looks ok, although if you wanna safe some money you could go for the older Ryzen 9 7950X. You will get the exact same performance and you will safe 300 Euros on the CPU and motherboard.
                Otherwise make sure your case is big enough to house your 4090, and that your CPU cooler supports the new Ryzen 9950X
                Best,
                Muhammed
                Hi, Just get my 7950x new pc, i notice that the CPU Temperature hit 95 degree when rendering, is it normal?
                Jackie Teh
                • #23
                  Yeah, normal.
                  Run V-Ray Benchmark for 10 minutes loop test, what score do you get?
                  Muhammed Hamed
                  chaos.com
                  • #24
                    Yeah, normal.
                    Here is the test result
                    Jackie Teh
                    • #25
                      Is the result ok?
                      Jackie Teh
                      • #26
                        Yeah, looks good!
                        Congratulations!
                        Muhammed Hamed
                        chaos.com
                        • #27
                          Yeah, looks good!
                          Congratulations!
                          Thank you to all of you for guide and help
                          Jackie Teh
